Inleiding
If you're looking for a simple step-by-step guide to help you replace the LCD screen on your Nikon D3000, this is a great place to start! If the LCD screen has been cracked, chipped or broken, the camera will need to be disassembled before the screen can be replaced.
Wat je nodig hebt
Remove three 3 mm x 2.5 mm Phillips head screws from the bottom right back of the camera bottom.
Remove one 3 mm x 5.5 mm Phillips head screw from the bottom left of the camera bottom.
Gently lift the back of the camera off, starting with the top first.
Lift off the bottom slightly to expose the ribbon connector connecting the back of the LCD screen to the motherboard of the camera and lift the black tab on the ribbon connector.
Pull the ribbon away from the connector to disconnect the back panel from the main body of the camera.
Remove six 5 mm x 4mm Phillips head screws , then remove the metal plate housing the LCD from the plastic camera backing.
After removing the metal plate housing, the buttons in the plastic camera backing are not secure. Be careful not to tip the backing, or you will have buttons everywhere!
Use the metal spudger to detach the LCD screen from the metal plate that is held down by the adhesive.
Install new LCD screen
8 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Completed this project but now my camera doesn’t turn on. Advice?
My D3000 camera will not display. I change the screen but it still will not display pls help what will i do now
