Ga door naar hoofdinhoud
Nikon Coolpix S9700 Screen Replacement
Wat je nodig hebt
  1. Nikon Coolpix S9700 Screen Replacement, Battery: stap 1, afbeelding 1 van 2 Nikon Coolpix S9700 Screen Replacement, Battery: stap 1, afbeelding 2 van 2
    • Press the ON/OFF button to power off the S9700.
    • Not doing so can damage the S9700 or cause electric shock.
  2. Nikon Coolpix S9700 Screen Replacement: stap 2, afbeelding 1 van 3 Nikon Coolpix S9700 Screen Replacement: stap 2, afbeelding 2 van 3 Nikon Coolpix S9700 Screen Replacement: stap 2, afbeelding 3 van 3
    • Place the S9700 upside down
    • Place your finger on the battery compartment cover and gently push toward the front of the S9700.
    • The cover will open up by itself.
  3. Nikon Coolpix S9700 Screen Replacement: stap 3, afbeelding 1 van 3 Nikon Coolpix S9700 Screen Replacement: stap 3, afbeelding 2 van 3 Nikon Coolpix S9700 Screen Replacement: stap 3, afbeelding 3 van 3
    • Push the yellow tab inside the battery compartment in the direction of the arrow. This will allow the battery to spring up.
  4. Nikon Coolpix S9700 Screen Replacement: stap 4, afbeelding 1 van 2 Nikon Coolpix S9700 Screen Replacement: stap 4, afbeelding 2 van 2
    • Grab the battery and pull out.
  5. Nikon Coolpix S9700 Screen Replacement, Back Panel: stap 5, afbeelding 1 van 2 Nikon Coolpix S9700 Screen Replacement, Back Panel: stap 5, afbeelding 2 van 2
    • Remove the two 4-mm and three 3-mm J000 screws from the bottom of the S9700.
    • Three 3-mm screws are on the side opposite the battery compartment.
    • Two 4-mm screws are on the side with the battery compartment. One of these screws is in the battery compartment. Open it up for access.
  6. Nikon Coolpix S9700 Screen Replacement: stap 6, afbeelding 1 van 2 Nikon Coolpix S9700 Screen Replacement: stap 6, afbeelding 2 van 2
    • Remove the one 3-mm J000 screw on the left side of the S9700 (side with no ports).
    • Remove the two 3-mm J000 screws on the right side (side with HDMI and charging ports).
    • One of these screws is underneath the HDMI port cover. Lift the port cover up to access.
  7. Nikon Coolpix S9700 Screen Replacement: stap 7, afbeelding 1 van 3 Nikon Coolpix S9700 Screen Replacement: stap 7, afbeelding 2 van 3 Nikon Coolpix S9700 Screen Replacement: stap 7, afbeelding 3 van 3
    • Insert the plastic opening tool on the bottom of the S9700 between the front panel and the back panel.
    • Twist the plastic opening tool so that both halves separate.
    • When both halves are separated, the HDMI cover, charging cover, and the ON/OFF switch will fall out.
    • There is a flex ribbon attached to the back panel. Forcing the back panel off may rip it.
  8. Nikon Coolpix S9700 Screen Replacement: stap 8, afbeelding 1 van 3 Nikon Coolpix S9700 Screen Replacement: stap 8, afbeelding 2 van 3 Nikon Coolpix S9700 Screen Replacement: stap 8, afbeelding 3 van 3
    • Remove the three silver 3-mm J000 screws on the back panel holding the silver button / dial component to the panel and ribbon.
    • Gently remove the back panel.
  9. Nikon Coolpix S9700 Screen Replacement, Screen: stap 9, afbeelding 1 van 3 Nikon Coolpix S9700 Screen Replacement, Screen: stap 9, afbeelding 2 van 3 Nikon Coolpix S9700 Screen Replacement, Screen: stap 9, afbeelding 3 van 3
    • Remove the 2-mm J000 screw located at the top of the S9700 just below the satellite picture and Wi-Fi marking.
    • Remove the two 4-mm J000 screws right below the zoom dial.
    • Remove the 4-mm J000 screw just above the battery compartment.
  10. Nikon Coolpix S9700 Screen Replacement: stap 10, afbeelding 1 van 3 Nikon Coolpix S9700 Screen Replacement: stap 10, afbeelding 2 van 3 Nikon Coolpix S9700 Screen Replacement: stap 10, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Remove the black film on the left side of the monitor using tweezers.
    • Remove the 2-mm J000 screw from underneath the black film.
  11. Nikon Coolpix S9700 Screen Replacement: stap 11, afbeelding 1 van 3 Nikon Coolpix S9700 Screen Replacement: stap 11, afbeelding 2 van 3 Nikon Coolpix S9700 Screen Replacement: stap 11, afbeelding 3 van 3
    • Lift the monitor from the rest of the S9700.
    • There is a ribbon cable attached to the monitor. Lift it very carefully.
    • Carefully lay the monitor down for full view of the ribbon
  12. Nikon Coolpix S9700 Screen Replacement: stap 12, afbeelding 1 van 3 Nikon Coolpix S9700 Screen Replacement: stap 12, afbeelding 2 van 3 Nikon Coolpix S9700 Screen Replacement: stap 12, afbeelding 3 van 3
    • Use tweezers to remove the ribbon. Grab as close as you can to where it plugs in to avoid ripping it.
    • Go from side to side with the tweezers, pulling only a little bit at a time.
    • Be very careful when working with the ribbon. The S9700 may not work if any of it is damaged.
  13. Nikon Coolpix S9700 Screen Replacement: stap 13, afbeelding 1 van 3 Nikon Coolpix S9700 Screen Replacement: stap 13, afbeelding 2 van 3 Nikon Coolpix S9700 Screen Replacement: stap 13, afbeelding 3 van 3
    • Remove the ribbon cable connecting the monitor and the silver button / dial component. Do this the same way that you did the other ribbon cable.
    • Be very careful working with ribbon cables. The S9700 may not work if you damage it in any way.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Matt Staubus
849 Reputatie
5 handleidingen geschreven
USF Tampa, Team 9-5, Lacy Fall 2016 Lid van USF Tampa, Team 9-5, Lacy Fall 2016
USFT-LACY-F16S9G5
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 37
Altijd: 2,446
