Ga door naar hoofdinhoud
Nikon Coolpix S9700 Memory Card Replacement
  1. Nikon Coolpix S9700 Memory Card Replacement, Memory Card: stap 1, afbeelding 1 van 3 Nikon Coolpix S9700 Memory Card Replacement, Memory Card: stap 1, afbeelding 2 van 3 Nikon Coolpix S9700 Memory Card Replacement, Memory Card: stap 1, afbeelding 3 van 3
    • Power off the S9700 and situate it so that it is upside down.
    • Place your finger on the compartment door.
    • Gently push toward the front of the S9700.
    • The compartment door should spring open by itself.
  2. Nikon Coolpix S9700 Memory Card Replacement: stap 2, afbeelding 1 van 3 Nikon Coolpix S9700 Memory Card Replacement: stap 2, afbeelding 2 van 3 Nikon Coolpix S9700 Memory Card Replacement: stap 2, afbeelding 3 van 3
    • Locate the memory card. Be careful not to mistake it for the battery.
    • Push down on the memory card until it won't go down further. Don't push too hard to avoid damaging your camera
    • Release your finger and the card will pop up out of its compartment.
  3. Nikon Coolpix S9700 Memory Card Replacement: stap 3, afbeelding 1 van 2 Nikon Coolpix S9700 Memory Card Replacement: stap 3, afbeelding 2 van 2
    • Grab your memory card with two fingers.
    • Gently pull up and your memory card will come out.
Conclusie
Matt Staubus
849 Reputatie
5 handleidingen geschreven
USF Tampa, Team 9-5, Lacy Fall 2016 Lid van USF Tampa, Team 9-5, Lacy Fall 2016
USFT-LACY-F16S9G5
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 588
