Ga door naar hoofdinhoud
Nikon Coolpix S7000 Sticky Button Replacement
Wat je nodig hebt
    • Clean your camera buttons. This can be done using isopropyl alcohol and a cotton swab. If the button is still jammed, proceed to Step 2.
  1. Nikon Coolpix S7000 Sticky Button Replacement: stap 2, afbeelding 1 van 3 Nikon Coolpix S7000 Sticky Button Replacement: stap 2, afbeelding 2 van 3 Nikon Coolpix S7000 Sticky Button Replacement: stap 2, afbeelding 3 van 3
    • Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
    • 3.2mm screws (not fully threaded)
    • 3mm screws
    • 4.2mm screws (coarser thread)
  2. Nikon Coolpix S7000 Sticky Button Replacement: stap 3, afbeelding 1 van 2 Nikon Coolpix S7000 Sticky Button Replacement: stap 3, afbeelding 2 van 2
    • Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
  3. Nikon Coolpix S7000 Sticky Button Replacement: stap 4, afbeelding 1 van 3 Nikon Coolpix S7000 Sticky Button Replacement: stap 4, afbeelding 2 van 3 Nikon Coolpix S7000 Sticky Button Replacement: stap 4, afbeelding 3 van 3
    • At this point push out any buttons that were jammed, and, clean the inside portion where the button sits inside the frames with isopropyl alcohol and a cotton swab as moisture may have found its way inside the camera causing stickiness.
    • Swab this portion.
  4. Nikon Coolpix S7000 Sticky Button Replacement: stap 5, afbeelding 1 van 1
    • If the navigation button is stuck, twist it around while the frame is removed to see if you can locate any obstructions.
    • If the shutter button is stuck, press up against it from the inside with your finger or the screwdriver to dislodge it.
  5. Nikon Coolpix S7000 Sticky Button Replacement: stap 6, afbeelding 1 van 1
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Shannon Beane
324 Reputatie
2 handleidingen geschreven
USF Tampa, Team S2-G3, Lacy Spring 2017 Lid van USF Tampa, Team S2-G3, Lacy Spring 2017
USFT-LACY-S17S2G3
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 30
Altijd: 2,287
