Ga door naar hoofdinhoud
Nikon Coolpix S6300 Display Replacement
Wat je nodig hebt
  1. Nikon Coolpix S6300 Display Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the camera facing upwards.
    • Press down on the battery cover and slide towards the front face of the camera.
  2. Nikon Coolpix S6300 Display Replacement: stap 2, afbeelding 1 van 1
    • Rotate the orange battery clip in the camera to release the battery.
  3. Nikon Coolpix S6300 Display Replacement, Buttons: stap 3, afbeelding 1 van 3 Nikon Coolpix S6300 Display Replacement, Buttons: stap 3, afbeelding 2 van 3 Nikon Coolpix S6300 Display Replacement, Buttons: stap 3, afbeelding 3 van 3
    • Locate the eight outer PH 2mm screws on the device.
    • Using the PH00 screwdriver remove all of the screws from the camera.
  4. Nikon Coolpix S6300 Display Replacement: stap 4, afbeelding 1 van 3 Nikon Coolpix S6300 Display Replacement: stap 4, afbeelding 2 van 3 Nikon Coolpix S6300 Display Replacement: stap 4, afbeelding 3 van 3
    • Using a plastic opening tool, gently pry off the front and rear plates.
    • Be patient with this step, do not force the clips holding the plates together.
  5. Nikon Coolpix S6300 Display Replacement: stap 5, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the PH 2mm screw located to the right of the screen, above the OK dial.
  6. Nikon Coolpix S6300 Display Replacement: stap 6, afbeelding 1 van 1
    • Remove the two clasp using a plastic spudger
    • Be careful when removing the clasp to prevent ripping of the clasp
  7. Nikon Coolpix S6300 Display Replacement: stap 7, afbeelding 1 van 1
    • You may now remove the internal panel of the buttons
  8. Nikon Coolpix S6300 Display Replacement, Display: stap 8, afbeelding 1 van 1
    • Remove the clasp from the ribbon cable using the plastic spudger.
    • Make sure to be gentle when removing the clasp to prevent it from ripping.
    • You may now remove the display.
Conclusie
Hung
383 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-2, Remmell Fall 2015 Lid van USF Tampa, Team 1-2, Remmell Fall 2015
USFT-REMMELL-F15S1G2
5 Leden
10 handleidingen geschreven
2 opmerkingen
Step 8 could have better pictures and explanation of the clasp...or picture of the clasp. I think it was some white tape looking stuff that I did break. Looking for better instructions elsewhere. I think I just made the situation worse
Lisa F - Antwoord
I have this problem with my coolpix (see images and video):
https://i.postimg.cc/pXk2L4QB/20190201-1...
https://i.postimg.cc/d3wYqjLX/20190201-1...
https://i.postimg.cc/RCLmgyYz/20190201-1...
https://drive.google.com/file/d/1sDr8fPD...
Screen has a posterized effect.
I already replaced the screen with a new one, but the problem remains..
Any idea what is faulty, and how can I fix it?
Geo Nik - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 19
Altijd: 1,419
