Ga door naar hoofdinhoud
Nikon Coolpix S630 Shutter Button Replacement
Wat je nodig hebt
  1. Nikon Coolpix S630 Shutter Button Replacement, Battery Compartment: stap 1, afbeelding 1 van 1
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Nikon Coolpix S630 Shutter Button Replacement, Battery: stap 2, afbeelding 1 van 1
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Nikon Coolpix S630 Shutter Button Replacement, Memory Card: stap 3, afbeelding 1 van 1
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. Nikon Coolpix S630 Shutter Button Replacement, Front Cover: stap 4, afbeelding 1 van 1
    • Locate a small, rectangular flap above the battery cover door.
    • Push the small, rectangular flap back through the hole.
  5. Nikon Coolpix S630 Shutter Button Replacement: stap 5, afbeelding 1 van 1
    • Using the plastic opening tool, gently pry open the front cover. Gently remove the front cover.
    • Make sure to hold the camera down when removing the front cover.
  6. Nikon Coolpix S630 Shutter Button Replacement, Shutter Button: stap 6, afbeelding 1 van 1
    • Place the front cover facing down so that you can easily see the shutter button.
  7. Nikon Coolpix S630 Shutter Button Replacement: stap 7, afbeelding 1 van 1
    • Using tweezers, gently slide the shutter button out.
    • Be very gentle because you can damage the piece.
Conclusie
Aulivia Bounchaleun
10 Reputatie
4 handleidingen geschreven
Cal Poly, Team 8-56, Johann Spring 2013 Lid van Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 31
Altijd: 2,180
