Inleiding
This guide will allow the user to be able to remove the outer casing of the camera as to allow them to get to the internal parts of the Nikon Coolpix S5300.
Wat je nodig hebt
Turn the camera upside down and locate the battery compartment.
Slide the compartment open following the direction of the arrow.
Remove the four 0.1mm screws from the bottom of the camera using the phillips head screwdriver
Using the same screwdriver, remove the 2 screws on the side of the camera.
Remove the 2 screws from the other side of the camera.
