Ga door naar hoofdinhoud
Nikon Coolpix S5200 LCD Screen Replacement
Wat je nodig hebt
  1. Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 3 Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 2 van 3 Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 3 van 3
    • There are four 0.1 mm screws holding the front and back of the camera together all along the outside of the camera
    • There should be four screws
  2. Nikon Coolpix S5200 LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Use the Phillips Head screw driver head to remove the four 0.1 mm screws surrounding the outer edges of the camera
  3. Nikon Coolpix S5200 LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Pull the plastic back cover off of and away from the LCD screen
  4. Nikon Coolpix S5200 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Carefully remove the LCD screen from the silver plate that once held it in place by pulling it away from the internal components
  5. Nikon Coolpix S5200 LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Remove the six designated screws sized 0.1 mm from the metal plate using a Phillip's Head screwdriver in size PH00.
  6. Nikon Coolpix S5200 LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • Lift the metal plate away from the internal components of the camera
  7. Nikon Coolpix S5200 LCD Screen Replacement: stap 7, afbeelding 1 van 2 Nikon Coolpix S5200 LCD Screen Replacement: stap 7, afbeelding 2 van 2
    • Carefully remove the LCD screen by pulling it away from the camera. Repeat these steps in reverse order to install the new LCD screen.
Conclusie
Andy Powers
391 Reputatie
3 handleidingen geschreven
Één opmerking
Shouldn't the replacement LCD screen be considered a part? It is in fact very difficult to replace it without having the part to replace.
joshronsen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 32
Altijd: 1,065
