Ga door naar hoofdinhoud
Nikon Coolpix S51c Lens Replacement
Wat je nodig hebt
  1. Nikon Coolpix S51c Lens Replacement, Back Cover: stap 1, afbeelding 1 van 2 Nikon Coolpix S51c Lens Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Remove all five screws from the bottom of the camera using a Phillips #00 screwdriver.
  2. Nikon Coolpix S51c Lens Replacement: stap 2, afbeelding 1 van 1
    • Open the battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
    • Remove this screw using a Phillips #00 screwdriver.
  3. Nikon Coolpix S51c Lens Replacement: stap 3, afbeelding 1 van 1
    • Rotate the camera to find the side panel with the lanyard attachment.
    • Detach the side panel by the lifting bottom corner slightly with the spudger.
  4. Nikon Coolpix S51c Lens Replacement: stap 4, afbeelding 1 van 1
    • Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
  5. Nikon Coolpix S51c Lens Replacement: stap 5, afbeelding 1 van 1
    • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
  6. Nikon Coolpix S51c Lens Replacement, Lens: stap 6, afbeelding 1 van 3 Nikon Coolpix S51c Lens Replacement, Lens: stap 6, afbeelding 2 van 3 Nikon Coolpix S51c Lens Replacement, Lens: stap 6, afbeelding 3 van 3
    • Remove the five screws on the metal plate.
    • One of them is in a hole in the corner of the metal plate.
    • Remove the screw at the bottom of the camera.
    • Carefully lift the metal plate from the right side to reveal a ribbon connected to the motherboard.
  7. Nikon Coolpix S51c Lens Replacement: stap 7, afbeelding 1 van 2 Nikon Coolpix S51c Lens Replacement: stap 7, afbeelding 2 van 2
    • Lift the white flap with the spudger to release the ribbon.
    • Remove the back metal plate.
  8. Nikon Coolpix S51c Lens Replacement: stap 8, afbeelding 1 van 3 Nikon Coolpix S51c Lens Replacement: stap 8, afbeelding 2 van 3 Nikon Coolpix S51c Lens Replacement: stap 8, afbeelding 3 van 3
    • Lift the two ribbons with the spudger to disconnect the lens and pull it out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ryan
155 Reputatie
6 handleidingen geschreven
Cal Poly, Team 18-24, Garner Spring 2011 Lid van Cal Poly, Team 18-24, Garner Spring 2011
CPSU-GARNER-S11S18G24
4 Leden
2 opmerkingen
question: any source for replacement lens block ? can't find any on the internet
Cyrille Dupuydauby - Antwoord
question: any source for lens block ? I can't find any on the internet
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 1,394
