Ga door naar hoofdinhoud
Nikon Coolpix S51c Back Cover Replacement
Wat je nodig hebt
  1. Nikon Coolpix S51c Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 2 Nikon Coolpix S51c Back Cover Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Remove all five screws from the bottom of the camera using a Phillips #00 screwdriver.
  2. Nikon Coolpix S51c Back Cover Replacement: stap 2, afbeelding 1 van 1
    • Open the battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
    • Remove this screw using a Phillips #00 screwdriver.
  3. Nikon Coolpix S51c Back Cover Replacement: stap 3, afbeelding 1 van 1
    • Rotate the camera to find the side panel with the lanyard attachment.
    • Detach the side panel by the lifting bottom corner slightly with the spudger.
  4. Nikon Coolpix S51c Back Cover Replacement: stap 4, afbeelding 1 van 1
    • Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
  5. Nikon Coolpix S51c Back Cover Replacement: stap 5, afbeelding 1 van 1
    • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ryan
155 Reputatie
6 handleidingen geschreven
Cal Poly, Team 18-24, Garner Spring 2011 Lid van Cal Poly, Team 18-24, Garner Spring 2011
CPSU-GARNER-S11S18G24
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,298
