Inleiding
If you need to replace the video record, playback, or camera mode buttons, then you must follow these steps to replace the metal plate with the mounted wiring.
Wat je nodig hebt
Using a Philips #000 head screwdriver, remove the 8 screws (3.30 mm) visible on the external part of the camera.
There are 2 on each side, and 4 on the bottom.
Using the Philips #000 head screwdriver, remove the 3.40 mm screw located near the functional buttons.
Één andere persoon heeft deze handleiding voltooid.
