Ga door naar hoofdinhoud
Nikon Coolpix S3500 Shutter Release Button Replacement
Wat je nodig hebt
  1. Nikon Coolpix S3500 Shutter Release Button Replacement, Back Panel Disassembly: stap 1, afbeelding 1 van 2 Nikon Coolpix S3500 Shutter Release Button Replacement, Back Panel Disassembly: stap 1, afbeelding 2 van 2
    • With the battery door facing upward, take your PH000 screwdriver and remove the 4 mm screws from the bottom of the device.
  2. Nikon Coolpix S3500 Shutter Release Button Replacement: stap 2, afbeelding 1 van 2 Nikon Coolpix S3500 Shutter Release Button Replacement: stap 2, afbeelding 2 van 2
    • After removing the screws, rotate the device to where the micro USB port is facing up.
    • Now, take your PH000 screwdriver and remove the two 4 mm screws from the device.
  3. Nikon Coolpix S3500 Shutter Release Button Replacement: stap 3, afbeelding 1 van 2 Nikon Coolpix S3500 Shutter Release Button Replacement: stap 3, afbeelding 2 van 2
    • Rotate the device 180 degrees so that the opposite side of the device is now facing upwards.
  4. Nikon Coolpix S3500 Shutter Release Button Replacement: stap 4, afbeelding 1 van 2 Nikon Coolpix S3500 Shutter Release Button Replacement: stap 4, afbeelding 2 van 2
    • After all of the screws are removed, rotate the device so that the bottom of the device is now facing upward.
    • With your index finger, press down and slide open the memory card/battery door.
  5. Nikon Coolpix S3500 Shutter Release Button Replacement: stap 5, afbeelding 1 van 3 Nikon Coolpix S3500 Shutter Release Button Replacement: stap 5, afbeelding 2 van 3 Nikon Coolpix S3500 Shutter Release Button Replacement: stap 5, afbeelding 3 van 3
    • Now take the plastic opening tool, and place it in the seam of the device.
    • Now, work the tool around the seam of the device until you can safely pry open the device.
  6. Nikon Coolpix S3500 Shutter Release Button Replacement: stap 6, afbeelding 1 van 2 Nikon Coolpix S3500 Shutter Release Button Replacement: stap 6, afbeelding 2 van 2
    • Be careful when removing the back piece of your device.
    • Using your free hand, finish prying off the back piece of the device.
  7. Nikon Coolpix S3500 Shutter Release Button Replacement, Shutter Release Button: stap 7, afbeelding 1 van 1
    • Place the device shutter side down onto your hand.
  8. Nikon Coolpix S3500 Shutter Release Button Replacement: stap 8, afbeelding 1 van 3 Nikon Coolpix S3500 Shutter Release Button Replacement: stap 8, afbeelding 2 van 3 Nikon Coolpix S3500 Shutter Release Button Replacement: stap 8, afbeelding 3 van 3
    • Take the thumb of the hand holding the device and place it on the plastic front panel.
    • Make sure to be gentle so no damage is done to any of the inner components of the device.
    • With your free hand, grip the outer edge of the LCD screen and start to pull the LCD from the front panel of the device.
    • This should cause the two pieces to separate from each other.
  9. Nikon Coolpix S3500 Shutter Release Button Replacement: stap 9, afbeelding 1 van 2 Nikon Coolpix S3500 Shutter Release Button Replacement: stap 9, afbeelding 2 van 2
    • Now that the 2 pieces are separated, take your free hand and gently press down on the shutter release button.
    • This should cause the shutter release button to come free from the front panel of the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jordan Rosemeyer
491 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 16
Altijd: 631
