Ga door naar hoofdinhoud
Nikon Coolpix S3100 disassembly
Wat je nodig hebt
  1. Nikon Coolpix S3100 disassembly, Nikon Coolpix S3100 disassembly: stap 1, afbeelding 1 van 3 Nikon Coolpix S3100 disassembly, Nikon Coolpix S3100 disassembly: stap 1, afbeelding 2 van 3 Nikon Coolpix S3100 disassembly, Nikon Coolpix S3100 disassembly: stap 1, afbeelding 3 van 3
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 disassembly: stap 2, afbeelding 1 van 2 Nikon Coolpix S3100 disassembly: stap 2, afbeelding 2 van 2
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 disassembly: stap 3, afbeelding 1 van 2 Nikon Coolpix S3100 disassembly: stap 3, afbeelding 2 van 2
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
Conclusie
Jorge
1.170 Reputatie
7 handleidingen geschreven
Colorado Springs, Team 2-4, Panko Spring 2015 Lid van Colorado Springs, Team 2-4, Panko Spring 2015
UCCS-PANKO-S15S2G4
2 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 43
Altijd: 1,988
