Inleiding
If you shutter lens does not seem to operate, these guides will help you find the problem.
Wat je nodig hebt
Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
Remove 2 screws from left side. (picture 1)
Remove 4 screws from bottom. (picture 2)
Remove 2 screws from right side. (picture 3)
11 andere personen hebben deze handleiding voltooid.
6 opmerkingen
My lens shutter does not open correctly. After turning the camera on, the shutter only half opens with a juddering motion. Any ideas?
Anita
Nikon coolpix s3100 lens mocking place help my
My lens shutter does not open correctly after turning on and after close with juddering repeatly how can be repaired
I have same issue it shutter half opens and doesnt open correctly
my LCD screen is stuck on white after after i did this :(
