Ga door naar hoofdinhoud
Nikon Coolpix S3100 Camera Disassembly
Wat je nodig hebt
  1. Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 disassembly: stap 1, afbeelding 1 van 3 Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 disassembly: stap 1, afbeelding 2 van 3 Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 disassembly: stap 1, afbeelding 3 van 3
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera Disassembly: stap 2, afbeelding 1 van 2 Nikon Coolpix S3100 Camera Disassembly: stap 2, afbeelding 2 van 2
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera Disassembly: stap 3, afbeelding 1 van 2 Nikon Coolpix S3100 Camera Disassembly: stap 3, afbeelding 2 van 2
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 Camera Disassembly: stap 4, afbeelding 1 van 2 Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 Camera Disassembly: stap 4, afbeelding 2 van 2
    • Remove 2-2.10mm screws using a #000 Phillips screwdriver.
    • Gently pull the orange board to the right. (picture 2)
  5. Nikon Coolpix S3100 Camera Disassembly: stap 5, afbeelding 1 van 3 Nikon Coolpix S3100 Camera Disassembly: stap 5, afbeelding 2 van 3 Nikon Coolpix S3100 Camera Disassembly: stap 5, afbeelding 3 van 3
    • Lift screen up holding the corners.
    • Gently pull to the left to release from ZIF connector. (picture 2)
    • Gently pull the orange board to the right. (picture 3)
  6. Nikon Coolpix S3100 Camera Disassembly: stap 6, afbeelding 1 van 2 Nikon Coolpix S3100 Camera Disassembly: stap 6, afbeelding 2 van 2
    • Remove 4-2.10mm screws using a #000 Phillips screwdriver.
    • Gently pull the shutter up. (picture 2)
  7. Nikon Coolpix S3100 Camera Disassembly: stap 7, afbeelding 1 van 2 Nikon Coolpix S3100 Camera Disassembly: stap 7, afbeelding 2 van 2
    • Lens is now separated from body.
    • Remove 3-2.12mm screws using #000 Phillips screwdriver.
  8. Nikon Coolpix S3100 Camera Disassembly: stap 8, afbeelding 1 van 3 Nikon Coolpix S3100 Camera Disassembly: stap 8, afbeelding 2 van 3 Nikon Coolpix S3100 Camera Disassembly: stap 8, afbeelding 3 van 3
    • Use a nylon or metal spudger to release the lens.
    • Repeat step 4 to the opposite side of the lens. (picture 2)
    • Lens is now separated from metal.
  9. Nikon Coolpix S3100 Camera Disassembly: stap 9, afbeelding 1 van 3 Nikon Coolpix S3100 Camera Disassembly: stap 9, afbeelding 2 van 3 Nikon Coolpix S3100 Camera Disassembly: stap 9, afbeelding 3 van 3
    • Once you have all the parts separated, start cleaning them with an air compressor bottle. (as shown)
    • Using the provided straw, start spraying the parts. (pictures 2 and 3)
Conclusie
Jorge
1.170 Reputatie
7 handleidingen geschreven
Colorado Springs, Team 2-4, Panko Spring 2015 Lid van Colorado Springs, Team 2-4, Panko Spring 2015
UCCS-PANKO-S15S2G4
2 Leden
13 handleidingen geschreven
Één opmerking
accidentally touched the wires for the cap even though i read the warning, can confirm, not fun
zettabyte - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 34
Altijd: 3,024
