Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Slide the battery and memory card cover (located on the bottom of the camera) to release it.
To release battery you must slide the orange hatch, once doing so the battery will pop up.
Remove with tweezers or your fingers.
To release the memory card, simply push down on the memory card and it will pop up as the battery did.
You will be able to remove with your fingers.
Één opmerking
Thank you! If you're like me, the way you push the memory card registers as "in," not "down," but I got it out!
