Ga door naar hoofdinhoud
Nikon Coolpix S220 Battery and Memory Card Replacement
Wat je nodig hebt
  1. Nikon Coolpix S220 Battery and Memory Card Replacement, Battery and Memory Card: stap 1, afbeelding 1 van 1
    • Slide the battery and memory card cover (located on the bottom of the camera) to release it.
  2. Nikon Coolpix S220 Battery and Memory Card Replacement: stap 2, afbeelding 1 van 1
    • To release battery you must slide the orange hatch, once doing so the battery will pop up.
    • Remove with tweezers or your fingers.
  3. Nikon Coolpix S220 Battery and Memory Card Replacement: stap 3, afbeelding 1 van 1
    • To release the memory card, simply push down on the memory card and it will pop up as the battery did.
    • You will be able to remove with your fingers.
Conclusie
Shauna
798 Reputatie
5 handleidingen geschreven
Cal Poly, Team 12-32, Maness Spring 2011 Lid van Cal Poly, Team 12-32, Maness Spring 2011
CPSU-MANESS-S11S12G32
4 Leden
10 handleidingen geschreven
Één opmerking
Thank you! If you're like me, the way you push the memory card registers as "in," not "down," but I got it out!
bonitakale - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 35
Altijd: 19,127
