Ga door naar hoofdinhoud
Nikon Coolpix S220 Accessing the Motherboard
Wat je nodig hebt
  1. Nikon Coolpix S220 Accessing the Motherboard, Outer Cover: stap 1, afbeelding 1 van 1
    • Remove the two 2.8 mm screws on the left side of the camera.
  2. Nikon Coolpix S220 Accessing the Motherboard: stap 2, afbeelding 1 van 1
    • Remove the four 2.8 mm screws on the right side of the camera.
  3. Nikon Coolpix S220 Accessing the Motherboard: stap 3, afbeelding 1 van 1
    • Remove the three 4.1 mm screws on the bottom of the camera.
  4. Nikon Coolpix S220 Accessing the Motherboard: stap 4, afbeelding 1 van 1
    • Gently lift the rear cover from the camera.
  5. Nikon Coolpix S220 Accessing the Motherboard, LCD: stap 5, afbeelding 1 van 1
    • Gently lift the screen out of its place.
    • You will need to hold the screen slightly above the camera because it will still be attached to the camera by an orange ribbon cable.
  6. Nikon Coolpix S220 Accessing the Motherboard: stap 6, afbeelding 1 van 1
    • Use the tweezers to lift the ZIF connector which is holding the ribbon cables that connect the LCD screen to the motherboard.
  7. Nikon Coolpix S220 Accessing the Motherboard: stap 7, afbeelding 1 van 1
    • Slowly pull the screen from the camera.
  8. Nikon Coolpix S220 Accessing the Motherboard, Motherboard: stap 8, afbeelding 1 van 1
    • Remove the four 3.8 mm screws located near the bottom right and top left of the LCD base plate.
  9. Nikon Coolpix S220 Accessing the Motherboard: stap 9, afbeelding 1 van 1
    • Lift up silver LCD base plate
  10. Nikon Coolpix S220 Accessing the Motherboard: stap 10, afbeelding 1 van 2 Nikon Coolpix S220 Accessing the Motherboard: stap 10, afbeelding 2 van 2
    • Using tweezers, lift up the retaining flap on the ZIF connector securing the button panel ribbon cable.
    • Slide the button panel ribbon cable out of its socket on the motherboard.
Conclusie
Shauna
798 Reputatie
5 handleidingen geschreven
Cal Poly, Team 12-32, Maness Spring 2011 Lid van Cal Poly, Team 12-32, Maness Spring 2011
CPSU-MANESS-S11S12G32
4 Leden
10 handleidingen geschreven
Één opmerking
It would be nice to have a guide for replacing the flash capacitor.
danwat1234 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 5,615
