Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Place thumb on the battery cover panel on the bottom of the device.
Slide the panel to the right away from the camera.
Slide the orange latch outward towards the corner of the camera.
The battery should pop out.
Remove the battery and reattach the cover.
After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
Unscrew the two 4.05mm screws on the side next to the buttons.
Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
Carefully pry the back case away from the camera and then gently lift it off.
To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up. The ribbon should slide out easily.
Repeat the same process with the smaller ribbon, this time looking for a light blue latch.
