Ga door naar hoofdinhoud
Nikon Coolpix P90 LCD Screen Replacement
Wat je nodig hebt
  1. Nikon Coolpix P90 LCD Screen Replacement, Camera Base: stap 1, afbeelding 1 van 3 Nikon Coolpix P90 LCD Screen Replacement, Camera Base: stap 1, afbeelding 2 van 3 Nikon Coolpix P90 LCD Screen Replacement, Camera Base: stap 1, afbeelding 3 van 3
    • Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
    • Push the door open, and remove the existing battery with your fingers, per images 2-3.
  2. Nikon Coolpix P90 LCD Screen Replacement, LCD Screen: stap 2, afbeelding 1 van 3 Nikon Coolpix P90 LCD Screen Replacement, LCD Screen: stap 2, afbeelding 2 van 3 Nikon Coolpix P90 LCD Screen Replacement, LCD Screen: stap 2, afbeelding 3 van 3
    • Use a Phillips #000 Precision Screwdriver for all of the following steps.
    • Remove both 4.5 mm screws holding the bottom into place.
    • Remove both 4.5 mm screws holding the side into place.
    • Remove the 4.5 mm screw underneath the A/V flap.
    • Remove the 4.0 mm screw on the left-side wrist strap loop.
  3. Nikon Coolpix P90 LCD Screen Replacement: stap 3, afbeelding 1 van 2 Nikon Coolpix P90 LCD Screen Replacement: stap 3, afbeelding 2 van 2
    • Lift up the LCD screen to reveal the two screws.
    • Using a Phillips #000 Precision Screwdriver, remove the two 3.0 mm screws that hold the arm in place.
  4. Nikon Coolpix P90 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Carefully lift the back cover from the camera.
    • Do NOT completely remove the back cover from the camera yet. There is a data transfer ribbon connecting the LCD screen to the motherboard.
  5. Nikon Coolpix P90 LCD Screen Replacement: stap 5, afbeelding 1 van 2 Nikon Coolpix P90 LCD Screen Replacement: stap 5, afbeelding 2 van 2
    • Press your finger on the top of the latch and pull it down and towards you to open the safety latch and free the ribbon.
    • Be careful when removing the safety latch as it is fragile and may break easily.
    • Slide the ribbon out from its socket.
    • It is now safe to completely remove the back cover from the camera.
  6. Nikon Coolpix P90 LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • Using a Phillips #000 Precision Screwdriver, remove the two 6.0 mm screws from the inner back panel that hold the LCD screen arm in place.
  7. Nikon Coolpix P90 LCD Screen Replacement: stap 7, afbeelding 1 van 3 Nikon Coolpix P90 LCD Screen Replacement: stap 7, afbeelding 2 van 3 Nikon Coolpix P90 LCD Screen Replacement: stap 7, afbeelding 3 van 3
    • Using a Phillips #000 Precision Screwdriver, remove the two 3.0 mm screws.
    • Remove the plastic cover from the LCD screen arm.
  8. Nikon Coolpix P90 LCD Screen Replacement: stap 8, afbeelding 1 van 3 Nikon Coolpix P90 LCD Screen Replacement: stap 8, afbeelding 2 van 3 Nikon Coolpix P90 LCD Screen Replacement: stap 8, afbeelding 3 van 3
    • Lift and rotate the plastic connector counter-clockwise, clockwise, then counter-clockwise again.
    • Remove the plastic connector from the LCD screen arm.
  9. Nikon Coolpix P90 LCD Screen Replacement: stap 9, afbeelding 1 van 2 Nikon Coolpix P90 LCD Screen Replacement: stap 9, afbeelding 2 van 2
    • Using a Phillips #000 Precision Screwdriver, remove the two 4.0 mm screws.
    • Take off the plastic covering to reveal the inner components of the LCD screen.
  10. Nikon Coolpix P90 LCD Screen Replacement: stap 10, afbeelding 1 van 2 Nikon Coolpix P90 LCD Screen Replacement: stap 10, afbeelding 2 van 2
    • Using a Phillips #000 Precision Screwdriver, remove the four 3.0 mm screws.
    • Using your fingers, remove the two plastic borders that case the LCD screen.
    • A plastic opening tool is not necessary, but may be helpful.
  11. Nikon Coolpix P90 LCD Screen Replacement: stap 11, afbeelding 1 van 2 Nikon Coolpix P90 LCD Screen Replacement: stap 11, afbeelding 2 van 2
    • Using a Phillips #000 Precision Screwdriver, remove both 3.5 mm screws from either side of the LCD screen.
    • Remove the LCD screen from the screen cover.
Conclusie
Elizabeth Kamine
655 Reputatie
6 handleidingen geschreven
Cal Poly, Team 20-14, Maness Winter 2015 Lid van Cal Poly, Team 20-14, Maness Winter 2015
CPSU-MANESS-W15S20G14
4 Leden
7 handleidingen geschreven
4 opmerkingen
Hello Elizabeth,
I have just followed the video’s for replacing a screen on my Coolpix P90.
The procedure was excellent and for an old Australian (born 1931) I never had a problem.
Just one question, is there a special way for reconnecting the data transfer ribbon.
Just cannot reconnect.
Thank you.
Regards, Noman
QLD Australia.
normanlaundry - Antwoord
Hello,
Where can I buy a screen for replacement?
Thanks - Paul
Paul - Antwoord
Help! I must be missing something. I only need to replace the screen and I can’t get the angled screen to lay flat. Because of this I cant access the two screws on the back “extension” piece allowing me to remove the plastic cover on the back of the screen. The camera is a coolpix P90. Any advice?
Alexis - Antwoord
I also need to know where to buy a new screen.
Everywhere I look on line there are only parts listed for newer models.
Thanks, Allen
Soothing Sounds - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 2,223
