Inleiding
A defective tripod mount can affect the quality of the images being captured. The following guide will show a replacement procedure for the mount ensuring clear and sharp images.
Wat je nodig hebt
Remove the six 4mm screws highlighted in red with the Phillips #000 screwdriver.
Remove the 5mm screw highlighted in orange with the Phillips #000 screwdriver.
Pop up the camera flash using the button below the lightning bolt on the left side of the camera.
Identify the small notch below the camera flash where the body of the camera and the back cover join.
Use plastic opening tools to pry the darker plastic piece under the camera flash from the lighter plastic camera body.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Gently lift the back cover away from the camera body.
A gold ribbon cable will join the back cover of the camera to the internal electronic components. Be careful not to remove the back cover without removing the cable since this part can easily break.
To remove the ribbon cable, gently pull the connector from the camera's internal electronic components using a pair of tweezers.
Identify two the remaining 4mm screws to be removed using the Philips #000 screwdriver.
