Ga door naar hoofdinhoud
Nikon Coolpix P530 Battery Replacement
Wat je nodig hebt
  1. Nikon Coolpix P530 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Identify the battery chamber found at the bottom of the device.
    • Ensure the camera is turned off before conducting any maintenance on the device.
  2. Nikon Coolpix P530 Battery Replacement: stap 2, afbeelding 1 van 3 Nikon Coolpix P530 Battery Replacement: stap 2, afbeelding 2 van 3 Nikon Coolpix P530 Battery Replacement: stap 2, afbeelding 3 van 3
    • Slide the switch to the left to open the battery chamber using your fingertip or plastic opening tools.
    • The spring loaded battery chamber door will swing open after the switch is moved.
  3. Nikon Coolpix P530 Battery Replacement: stap 3, afbeelding 1 van 3 Nikon Coolpix P530 Battery Replacement: stap 3, afbeelding 2 van 3 Nikon Coolpix P530 Battery Replacement: stap 3, afbeelding 3 van 3
    • Depress the yellow spring loaded tab holding the battery in place using your fingertip or plastic opening tools.
    • After the yellow tab is depressed, the battery should partially eject from the camera.
  4. Nikon Coolpix P530 Battery Replacement: stap 4, afbeelding 1 van 2 Nikon Coolpix P530 Battery Replacement: stap 4, afbeelding 2 van 2
    • Gently remove the battery from the chamber.
Conclusie
3 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Thanks. Just checking the camera issues.
Suzanne von Leuschner - Antwoord
I can’t get the battery out of my camera. I've had the camera for 5 years with no previous problems. Any suggestions?
Bonnie Laub - Antwoord
top of the battery gets very hot when inserted .Is this normal?
Lowell Schiller - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 33
Altijd: 3,719
