Ga door naar hoofdinhoud
Nikon Coolpix P510 Battery Removal Replacement
Wat je nodig hebt
  1. Nikon Coolpix P510 Battery Removal Replacement, Battery Removal: stap 1, afbeelding 1 van 1
    • Flip the camera over and push the tab on the battery cover to open the battery compartment.
  2. Nikon Coolpix P510 Battery Removal Replacement: stap 2, afbeelding 1 van 2 Nikon Coolpix P510 Battery Removal Replacement: stap 2, afbeelding 2 van 2
    • Push the little yellow tab to allow the battery to slide out.
    • With the tab pushed out, pull the battery out.
Conclusie
Brian Hulsey
1.461 Reputatie
6 handleidingen geschreven
Colorado Springs, Team 2-2, Panko Spring 2015 Lid van Colorado Springs, Team 2-2, Panko Spring 2015
UCCS-PANKO-S15S2G2
3 Leden
12 handleidingen geschreven
3 opmerkingen
Even a 3 grader can figure this out. My problem is that I do this and the battery doesn't come up. It's stuck. What should I do???
victoria - Antwoord
Victoria, has had that problem too. In my case the battery was bloated. I had to wiggle it out with a butter knife until I could get a grip on it. I had to replace the battery.
david murray - Antwoord
Thank you so much for this information. I used a metal nail file and small pliers. It worked and the battery was swollen
klrider1961 -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 33
Altijd: 4,119
