Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Flip the camera upside down so that the side with the serial number is face up.
Pull back the display panel. Orient the panel so that you are able to view the back of it.
Remove the two screws closest to the piece connecting the panel to the camera with a Phillips #1 screwdriver.
Remove the cover that was unscrewed in the last step.
Remove the remaining four screws on the outermost corners of the panel using a Phillips #1 screwdriver.
Use a plastic opening tool to pry open the back panel of the display screen.
Carefully unhook the ribbon that attaches the panel to the camera.
Remove the top black panel cover.
Remove the two screws on the panel that are closest to the ribbon cable using a Phillips #1 screwdriver.
Remove the other two screws on the opposite side of the panel using a Phillips #1 screwdriver.
Separate the metal portion of the screen from the plastic portion.
Carefully remove the ribbon connector cable from the metal portion of the display.
Remove the display from the rest of the device.
5 andere personen hebben deze handleiding voltooid.
3 opmerkingen
This guide help me to change my screen on Nikon P100 with out to much trouble, however I found step 7 unnecessary.
