Ga door naar hoofdinhoud
Nikon Coolpix P100 Display Screen Replacement
Wat je nodig hebt
  1. Nikon Coolpix P100 Display Screen Replacement, Display Screen: stap 1, afbeelding 1 van 3 Nikon Coolpix P100 Display Screen Replacement, Display Screen: stap 1, afbeelding 2 van 3 Nikon Coolpix P100 Display Screen Replacement, Display Screen: stap 1, afbeelding 3 van 3
    • Flip the camera upside down so that the side with the serial number is face up.
    • Pull back the display panel. Orient the panel so that you are able to view the back of it.
  2. Nikon Coolpix P100 Display Screen Replacement: stap 2, afbeelding 1 van 2 Nikon Coolpix P100 Display Screen Replacement: stap 2, afbeelding 2 van 2
    • Remove the two screws closest to the piece connecting the panel to the camera with a Phillips #1 screwdriver.
  3. Nikon Coolpix P100 Display Screen Replacement: stap 3, afbeelding 1 van 1
    • Remove the cover that was unscrewed in the last step.
  4. Nikon Coolpix P100 Display Screen Replacement: stap 4, afbeelding 1 van 1
    • Remove the remaining four screws on the outermost corners of the panel using a Phillips #1 screwdriver.
  5. Nikon Coolpix P100 Display Screen Replacement: stap 5, afbeelding 1 van 3 Nikon Coolpix P100 Display Screen Replacement: stap 5, afbeelding 2 van 3 Nikon Coolpix P100 Display Screen Replacement: stap 5, afbeelding 3 van 3
    • Use a plastic opening tool to pry open the back panel of the display screen.
  6. Nikon Coolpix P100 Display Screen Replacement: stap 6, afbeelding 1 van 3 Nikon Coolpix P100 Display Screen Replacement: stap 6, afbeelding 2 van 3 Nikon Coolpix P100 Display Screen Replacement: stap 6, afbeelding 3 van 3
    • Carefully unhook the ribbon that attaches the panel to the camera.
    • Remove the top black panel cover.
  7. Nikon Coolpix P100 Display Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove the two screws on the panel that are closest to the ribbon cable using a Phillips #1 screwdriver.
  8. Nikon Coolpix P100 Display Screen Replacement: stap 8, afbeelding 1 van 1
    • Remove the other two screws on the opposite side of the panel using a Phillips #1 screwdriver.
  9. Nikon Coolpix P100 Display Screen Replacement: stap 9, afbeelding 1 van 2 Nikon Coolpix P100 Display Screen Replacement: stap 9, afbeelding 2 van 2
    • Separate the metal portion of the screen from the plastic portion.
  10. Nikon Coolpix P100 Display Screen Replacement: stap 10, afbeelding 1 van 2 Nikon Coolpix P100 Display Screen Replacement: stap 10, afbeelding 2 van 2
    • Carefully remove the ribbon connector cable from the metal portion of the display.
    • Remove the display from the rest of the device.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Rikki Brown
267 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-1, Tanski Winter 2015 Lid van USF Tampa, Team 1-1, Tanski Winter 2015
USFT-TANSKI-W15S1G1
3 Leden
8 handleidingen geschreven
3 opmerkingen
This guide help me to change my screen on Nikon P100 with out to much trouble, however I found step 7 unnecessary.
David Fyock - Antwoord
Hello, I've a problem during the re-mount of the display. Someone can help me? Thanks in advance! Mark
cwmark56 - Antwoord
I can't reconnect the connector on the step 10. Can you help me?
cwmark56 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 29
Altijd: 2,708
