Ga door naar hoofdinhoud
Nikon Coolpix L840 Buttons Replacement
Wat je nodig hebt
  1. Nikon Coolpix L840 Buttons Replacement, Motherboard: stap 1, afbeelding 1 van 3 Nikon Coolpix L840 Buttons Replacement, Motherboard: stap 1, afbeelding 2 van 3 Nikon Coolpix L840 Buttons Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
  2. Nikon Coolpix L840 Buttons Replacement: stap 2, afbeelding 1 van 1
    • Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
    • Be careful not to damage the inner components of the camera when slipping the spludger into the camera.
  3. Nikon Coolpix L840 Buttons Replacement: stap 3, afbeelding 1 van 2 Nikon Coolpix L840 Buttons Replacement: stap 3, afbeelding 2 van 2
    • Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
    • The strip may also be identified by its blue tip, which becomes more visible once pulled out.
  4. Nikon Coolpix L840 Buttons Replacement, Buttons: stap 4, afbeelding 1 van 1
    • Unscrew the two, right-most, 2 mm screws with a Philips 000.
    • Unscrew the left-most, 4 mm screw with a Philips 000.
  5. Nikon Coolpix L840 Buttons Replacement: stap 5, afbeelding 1 van 1
    • Slide off the button panel in the marked direction.
  6. Nikon Coolpix L840 Buttons Replacement: stap 6, afbeelding 1 van 1
    • Flip to the front side of the button panel to access the button sensors.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Abraham Lozano
595 Reputatie
4 handleidingen geschreven
Cal Poly, Team 1-11, Maness Spring 2016 Lid van Cal Poly, Team 1-11, Maness Spring 2016
CPSU-MANESS-S16S1G11
4 Leden
10 handleidingen geschreven
Één opmerking
Where can I get a replacement board for the buttons?
rush - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 2,209
