Inleiding
Is your LCD screen not displaying anything or is displaying a corrupted image? Follow this guide to replace the LCD screen.
Onderdelen
Geen onderdelen nodig.
  1. Remove two 5 mm Phillips #000 screws on the right hand side of the camera located near the power button. Use of precision tweezers to help remove loosened screws is suggested.
    • Remove two 5 mm Phillips #000 screws on the right hand side of the camera located near the power button.
    • Use of precision tweezers to help remove loosened screws is suggested.
  2. Remove two 5 mm Phillips #000 screws near the audio/video inputs on the opposite side near the flash component. Remove two 5 mm Phillips #000 screws near the audio/video inputs on the opposite side near the flash component.
    • Remove two 5 mm Phillips #000 screws near the audio/video inputs on the opposite side near the flash component.
  3. Remove three 5 mm Phillips #000 screws on the bottom end of the camera. Remove three 5 mm Phillips #000 screws on the bottom end of the camera.
    • Remove three 5 mm Phillips #000 screws on the bottom end of the camera.
  4. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  5. Carefully detach the back side of the camera by lifting both ends, with moderate force wobble until loosened enough to remove.
    • Carefully detach the back side of the camera by lifting both ends, with moderate force wobble until loosened enough to remove.
  6. With the LCD screen facing towards you, flip the screen to the right. With the LCD screen facing towards you, flip the screen to the right.
    • With the LCD screen facing towards you, flip the screen to the right.
  7. Remove three 5 mm Phillips #000 screws located on the bracket. Hold the camera with the lens facing downward to prevent the bracket from falling off once all screws are removed. Hold the camera with the lens facing downward to prevent the bracket from falling off once all screws are removed.
    • Remove three 5 mm Phillips #000 screws located on the bracket.
    • Hold the camera with the lens facing downward to prevent the bracket from falling off once all screws are removed.
  8. Disconnect the ribbons that connect the LCD screen to the camera gently using precision tweezers or fingers. Disconnect the ribbons that connect the LCD screen to the camera gently using precision tweezers or fingers.
    • Disconnect the ribbons that connect the LCD screen to the camera gently using precision tweezers or fingers.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Emilio Mena
713 Reputatie
4 handleidingen geschreven
UW Tacoma, Team 3-1, Rose Winter 2015 Lid van UW Tacoma, Team 3-1, Rose Winter 2015
UWT-ROSE-W15S3G1
4 Leden
Één commentaar
I love ifixit instructions so much more than youtube. These are so easy and straightfoward and I love how screw sizes are carefully specified.
Susan - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 26
Altijd: 1,600
