Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This is a guide to remove the power button. It is a simple task that can be done after removing the outer case of the camera.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device. Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
    • Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
  2. Remove the top (4.10 mm)  Phillips #00 screw adjacent to the battery compartment.
    • Remove the top (4.10 mm) Phillips #00 screw adjacent to the battery compartment.
    • Remove the bottom (3.20 mm) Phillips #00 screw adjacent to the battery compartment.
  3. Remove the top (4.20 mm) Phillips #00 screw adjacent  to the mic side of the camera and opposite the battery side.
    • Remove the top (4.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite the battery side.
    • Remove the lower (3.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite of the battery side.
  4. Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera. Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera. Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
    • Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
  5. Remove the panel containing the power and shutter button.
    • Remove the panel containing the power and shutter button.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alex Miragliotta
158 Reputatie
1 Handleiding geschreven
USF Tampa, Team 9-4, Brown Winter 2015 Lid van USF Tampa, Team 9-4, Brown Winter 2015
USFT-BROWN-W15S9G4
4 Leden
12 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 558
