Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
Remove the top (4.10 mm) Phillips #00 screw adjacent to the battery compartment.
Remove the bottom (3.20 mm) Phillips #00 screw adjacent to the battery compartment.
Remove the top (4.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite the battery side.
Remove the lower (3.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite of the battery side.
Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
Using a prying tool, carefully lift up the LCD screen but do NOT pull it off.
While the LCD screen is loose and unattached, there is a latch that is holding the ribbon in place. Slide the latch down and pull the ribbon out.
