Inleiding
In this guide, one would have to take the camera apart. After taking the camera apart, one will need to remove the screws from the control panel and remove the ribbon for it.
Wat je nodig hebt
Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
Carefully unscrew and remove the top and bottom (2.25 mm) screws from the control panel.
Carefully unscrew and remove the middle (3.20 mm) screws from the control panel.
