Ga door naar hoofdinhoud
Nikon Coolpix L340 Memory Card Replacement
  1. Nikon Coolpix L340 Memory Card Replacement, Memory Card: stap 1, afbeelding 1 van 2 Nikon Coolpix L340 Memory Card Replacement, Memory Card: stap 1, afbeelding 2 van 2
    • Turn the camera so that the flash is facing downward- you are now looking at the bottom of the camera.
    • If the camera lens is pointing towards you, there should be a small lever on the right hand side.
    • Take this lever and push it away from your body, while simultaneously pulling upwards.
  2. Nikon Coolpix L340 Memory Card Replacement: stap 2, afbeelding 1 van 1
    • Gently press down on the memory card until you hear a click, then release the pressure to eject the card and slowly pull it upwards out of the slot.
Conclusie
Kelly Kryzak
140 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 3-3, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G3
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 25
Altijd: 1,511
