Ga door naar hoofdinhoud
Nikon Coolpix L340 Buttons Replacement
Wat je nodig hebt
  1. Nikon Coolpix L340 Buttons Replacement, Buttons: stap 1, afbeelding 1 van 1
    • Remove the 5 mm Phillips #000 screw located on the upper left side of the camera
    • Remove the 5 mm Phillips #000 screw located on the lower left side of the camera
  2. Nikon Coolpix L340 Buttons Replacement: stap 2, afbeelding 1 van 1
    • Remove the 5 mm Phillips #000 screw from the upper right side of the camera.
    • Remove the 5 mm Phillips #000 screw from the lower right side of the camera.
  3. Nikon Coolpix L340 Buttons Replacement: stap 3, afbeelding 1 van 1
    • Remove the 5 mm Phillips #000 screw from the bottom left of the camera.
    • Remove the 5 mm Phillips #000 screw from the left-center of the bottom of the camera.
    • Remove the 5 mm Phillips #000 screw from the center of the bottom of the camera.
  4. Nikon Coolpix L340 Buttons Replacement: stap 4, afbeelding 1 van 1
    • Remove back cover of the camera.
  5. Nikon Coolpix L340 Buttons Replacement: stap 5, afbeelding 1 van 1
    • Push buttons out of the back of the cover.
Conclusie
Robert Estrella
101 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 3-3, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G3
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 1,212
