Ga door naar hoofdinhoud
Nikon Coolpix L340 Battery Replacement
  1. Nikon Coolpix L340 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Nikon Coolpix L340 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the camera so that the flash is facing downward- you are now looking at the bottom of the camera
    • If the camera lens its pointing towards you, there should be a small lever on the right hand side
    • Take this lever and push it away from your body, while simultaneously pulling upwards
  2. Nikon Coolpix L340 Battery Replacement: stap 2, afbeelding 1 van 2 Nikon Coolpix L340 Battery Replacement: stap 2, afbeelding 2 van 2
    • Once you have pulled up, four batteries will appear underneith
    • Note how there are two batteries facing upwards (circled in red)
    • and two batteries facing downwards (circled in orange)
    • When the new batteries are placed back in the camera, they should be put back in this same orientation
  3. Nikon Coolpix L340 Battery Replacement: stap 3, afbeelding 1 van 1
    • Take out each of the batteries
  4. Nikon Coolpix L340 Battery Replacement: stap 4, afbeelding 1 van 1
    • When all of the batteries have been removed you should see four places for four new batteries to be inserted
Conclusie
Nikki Butts
179 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 3-3, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G3
4 Leden
8 handleidingen geschreven
4 opmerkingen
Hi, I just replaced my Nikon Coolpix L340's batteries with new AAs and have followed all steps correctly but my camera is still saying 'battery exhausted' when I try turning it back on. Any ideas why it's not working?
Thank you!
Mia - Antwoord
The negative terminal must be raised like the Duracell Ultra. The Energizer MAX and other AAs have a FLAT negative terminal. The manual warns against them.
thestevelink -
No lever, only recessed button
ccpotts47 - Antwoord
thestevelink - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 128
Altijd: 9,735
