Inleiding
In order to replace this part of the camera, you will need to use the spudger tool and the Phillips screwdriver. Maker sure to keep track of all the screws as you take the device apart.
Wat je nodig hebt
Remove the batteries from the battery compartment by sliding the white battery compartment switch up and then move the panel toward the right.
Carefully flip over the LCD screen onto its front. Pull the top of the LCD screen toward you keeping the bottom of it inside the camera.
Open the battery compartment door by sliding the white switch upwards. Push the door towards the right of the camera.
Één andere persoon heeft deze handleiding voltooid.
