Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
Open the battery door.
Remove two Phillips screws (3.4 mm) located on the left side of the screen.
Remove two Phillips screws (3.4 mm) located on the right side of the screens.
Remove the Phillips screw on the top right side of the screen.
Carefully unplug the grey bundle of wires in the white housing.
Carefully unplug the small pink and wires in the grey housing.
Remove the two Phillips screws on the left side of the screen.
Remove the metal bar on the left side of the screen.
Remove the screen from the front plastic housing.
Één andere persoon heeft deze handleiding voltooid.
