Ga door naar hoofdinhoud
Nikon Coolpix B700 Button Assembly Replacement
Wat je nodig hebt
  1. Nikon Coolpix B700 Button Assembly Replacement, Back Frame Assembly: stap 1, afbeelding 1 van 1
    • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
  2. Nikon Coolpix B700 Button Assembly Replacement: stap 2, afbeelding 1 van 1
    • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
  3. Nikon Coolpix B700 Button Assembly Replacement: stap 3, afbeelding 1 van 2 Nikon Coolpix B700 Button Assembly Replacement: stap 3, afbeelding 2 van 2
    • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
    • Open the HDMI flap to remove a 5.5mm screw.
    • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
  4. Nikon Coolpix B700 Button Assembly Replacement: stap 4, afbeelding 1 van 1
    • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
  5. Nikon Coolpix B700 Button Assembly Replacement: stap 5, afbeelding 1 van 3 Nikon Coolpix B700 Button Assembly Replacement: stap 5, afbeelding 2 van 3 Nikon Coolpix B700 Button Assembly Replacement: stap 5, afbeelding 3 van 3
    • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
    • While twisting, pry apart the shell to split the camera in half.
  6. Nikon Coolpix B700 Button Assembly Replacement: stap 6, afbeelding 1 van 1
    • Be careful not to damage the ribbons that connect the halves together.
  7. Nikon Coolpix B700 Button Assembly Replacement: stap 7, afbeelding 1 van 2 Nikon Coolpix B700 Button Assembly Replacement: stap 7, afbeelding 2 van 2
    • Place the pry tool under the black latch. Lift gently until the latch flips up.
    • Gently pull the ribbon away from the latch.
    • Be gentle when taking ribbons out and apart because they are fragile.
  8. Nikon Coolpix B700 Button Assembly Replacement, Button Assembly: stap 8, afbeelding 1 van 1
    • Lift the corner under the power button up.
    • While at the same time pushing the selector knob back.
  9. Nikon Coolpix B700 Button Assembly Replacement: stap 9, afbeelding 1 van 1
    • This should remove the entire assembly from the camera housing.
Conclusie
3 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 25
Altijd: 458
