Ga door naar hoofdinhoud
Nikon Coolpix AW130 Shutter Button Replacement
Wat je nodig hebt
  1. Nikon Coolpix AW130 Shutter Button Replacement, Battery: stap 1, afbeelding 1 van 2 Nikon Coolpix AW130 Shutter Button Replacement, Battery: stap 1, afbeelding 2 van 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Shutter Button Replacement: stap 2, afbeelding 1 van 2 Nikon Coolpix AW130 Shutter Button Replacement: stap 2, afbeelding 2 van 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Shutter Button Replacement: stap 3, afbeelding 1 van 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Shutter Button Replacement: stap 4, afbeelding 1 van 2 Nikon Coolpix AW130 Shutter Button Replacement: stap 4, afbeelding 2 van 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Shutter Button Replacement, Front Panel: stap 5, afbeelding 1 van 2 Nikon Coolpix AW130 Shutter Button Replacement, Front Panel: stap 5, afbeelding 2 van 2
    • Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
    • Carefully pull the plate off of the face.
  6. Nikon Coolpix AW130 Shutter Button Replacement: stap 6, afbeelding 1 van 2 Nikon Coolpix AW130 Shutter Button Replacement: stap 6, afbeelding 2 van 2
    • Using the metal spudger tool, pry the colored face from the camera body.
    • Avoid bending or scratching the front face.
  7. Nikon Coolpix AW130 Shutter Button Replacement, Shutter Button: stap 7, afbeelding 1 van 2 Nikon Coolpix AW130 Shutter Button Replacement, Shutter Button: stap 7, afbeelding 2 van 2
    • Using your thumb, separate the top piece of plastic from the camera.
    • If this piece does not come loose easily, try using the nylon spudger.
  8. Nikon Coolpix AW130 Shutter Button Replacement: stap 8, afbeelding 1 van 3 Nikon Coolpix AW130 Shutter Button Replacement: stap 8, afbeelding 2 van 3 Nikon Coolpix AW130 Shutter Button Replacement: stap 8, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers from the precision tweezer set, carefully loosen the shutter button.
    • Atop the camera, there are two buttons. The shutter button should be the largest of the two.
Conclusie
Lauren Stepp
1.251 Reputatie
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 1,090
