Ga door naar hoofdinhoud
Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement
Wat je nodig hebt
  1. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Battery: stap 1, afbeelding 1 van 2 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Battery: stap 1, afbeelding 2 van 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: stap 2, afbeelding 1 van 2 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: stap 2, afbeelding 2 van 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: stap 3, afbeelding 1 van 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: stap 4, afbeelding 1 van 2 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: stap 4, afbeelding 2 van 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Map/Wi-Fi/Action Buttons: stap 5, afbeelding 1 van 3 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Map/Wi-Fi/Action Buttons: stap 5, afbeelding 2 van 3 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Map/Wi-Fi/Action Buttons: stap 5, afbeelding 3 van 3
    • Using the spudger, pry the plastic button face from the camera body.
    • The sharp edges of the spudger could cut you or pierce an exposed battery.
  6. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers from the precision tweezer set, remove the buttons from the larger plastic piece.
  7. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: stap 7, afbeelding 1 van 1
    • Using tweezers from the precision tweezer set, remove the silicon backing from the buttons.
    • From there, the buttons should dislodge from their plastic casing.
Conclusie
Lauren Stepp
1.251 Reputatie
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 680
