Ga door naar hoofdinhoud
Nikon Coolpix AW130 Front Panel Replacement
Wat je nodig hebt
  1. Nikon Coolpix AW130 Front Panel Replacement, Battery: stap 1, afbeelding 1 van 2 Nikon Coolpix AW130 Front Panel Replacement, Battery: stap 1, afbeelding 2 van 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Front Panel Replacement: stap 2, afbeelding 1 van 2 Nikon Coolpix AW130 Front Panel Replacement: stap 2, afbeelding 2 van 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Front Panel Replacement: stap 3, afbeelding 1 van 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Front Panel Replacement: stap 4, afbeelding 1 van 2 Nikon Coolpix AW130 Front Panel Replacement: stap 4, afbeelding 2 van 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Front Panel Replacement, Front Panel: stap 5, afbeelding 1 van 2 Nikon Coolpix AW130 Front Panel Replacement, Front Panel: stap 5, afbeelding 2 van 2
    • Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
    • Carefully pull the plate off of the face.
  6. Nikon Coolpix AW130 Front Panel Replacement: stap 6, afbeelding 1 van 2 Nikon Coolpix AW130 Front Panel Replacement: stap 6, afbeelding 2 van 2
    • Using the metal spudger tool, pry the colored face from the camera body.
    • Avoid bending or scratching the front face.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Lauren Stepp
1.251 Reputatie
8 handleidingen geschreven
Één opmerking
Hello, has this front panel influence on cameras sealing function? Or is it only as shield against mechanical demage?
Slavomir - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 1,527
