Ga door naar hoofdinhoud
Nikon Coolpix AW130 Battery Replacement
  1. Nikon Coolpix AW130 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Nikon Coolpix AW130 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Battery Replacement: stap 2, afbeelding 1 van 2 Nikon Coolpix AW130 Battery Replacement: stap 2, afbeelding 2 van 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Battery Replacement: stap 3, afbeelding 1 van 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Battery Replacement: stap 4, afbeelding 1 van 2 Nikon Coolpix AW130 Battery Replacement: stap 4, afbeelding 2 van 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
Conclusie
Lauren Stepp
1.251 Reputatie
8 handleidingen geschreven
Één opmerking
Try the following before ordering your battery :
The problem with my cool pix aw130 was the little yellow plastic tab ( seen in one of the above photos ; step 3 ) that supposed to keep the battery shoved tightly against the terminals . In time , it wears and the battery no longer makes contact ; hence never getting recharged . The fix is simple ! Cut a 1/4” x 1/4” piece of paper , cardboard , or plastic , and wedge it between the yellow tab and the battery . Then recharge , as before .
Franklin Noel Stein - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 16
Altijd: 2,613
