Ga door naar hoofdinhoud
Nikon Coolpix AW130 Battery Door Replacement
Wat je nodig hebt
  1. Nikon Coolpix AW130 Battery Door Replacement, Battery: stap 1, afbeelding 1 van 2 Nikon Coolpix AW130 Battery Door Replacement, Battery: stap 1, afbeelding 2 van 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Battery Door Replacement: stap 2, afbeelding 1 van 2 Nikon Coolpix AW130 Battery Door Replacement: stap 2, afbeelding 2 van 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Battery Door Replacement: stap 3, afbeelding 1 van 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Battery Door Replacement: stap 4, afbeelding 1 van 2 Nikon Coolpix AW130 Battery Door Replacement: stap 4, afbeelding 2 van 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Battery Door Replacement, Battery Door: stap 5, afbeelding 1 van 2 Nikon Coolpix AW130 Battery Door Replacement, Battery Door: stap 5, afbeelding 2 van 2
    • Using a Phillips #00 screwdriver, remove the 2, 4mm screws on the underside of the camera.
  6. Nikon Coolpix AW130 Battery Door Replacement: stap 6, afbeelding 1 van 1
    • Using the metal spudger, carefully pry on the plastic plate.
    • The plastic plate should begin to loosen. Completely remove it from the camera body.
  7. Nikon Coolpix AW130 Battery Door Replacement: stap 7, afbeelding 1 van 2 Nikon Coolpix AW130 Battery Door Replacement: stap 7, afbeelding 2 van 2
    • Open the battery door. Near the hinge, a pair of screws should now be exposed.
    • Using a Phillips #00 screwdriver, remove the 2, 4mm screws.
  8. Nikon Coolpix AW130 Battery Door Replacement: stap 8, afbeelding 1 van 1
    • Pull the battery door away from the camera body.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Lauren Stepp
1.251 Reputatie
8 handleidingen geschreven
6 opmerkingen
Where can I purchase the battery cover?
Thanh Tran - Antwoord
Where can I buy the AW130 battery door?
Jose - Antwoord
I’m trying to replace the battery door. I removed the 2 bottom screws and loosened the plate as in Steps 5 and 6. How do I remove the plate without breaking it?
Jose - Antwoord
like jose I have removed the screws and loosened the plate but can’t figure out how to remove it. How do I get it out?
Marianne Chaffin Strickland - Antwoord
Need web site to order battery door?
Connie Mossor - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 27
Altijd: 4,142
