Inleiding
If you're having problems with your memory card, this guide will show you how to remove and replace your memory card in the Nikon Coolpix 995.
  1. Set camera so the memory card compartment is facing you.
    • Set camera so the memory card compartment is facing you.
    • Place thumb under cover latch where it says "card", then gently lift straight upwards.
  2. Now that the Memory card compartment is open, carefully remove the memory card.
    • Now that the Memory card compartment is open, carefully remove the memory card.
    • Be sure your memory card is facing the right direction, then gently insert it into the memory card slot.
    • After you properly reinsert the memory card, place your thumb on the top of the cover and gently press down until you hear and feel the cover click back into the closed position.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cory Layman
89 Reputatie
3 handleidingen geschreven
UW Stout, Team 1-5, Zhou Fall 2011 Lid van UW Stout, Team 1-5, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G5
5 Leden
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 4
Altijd: 1,693
