Ga door naar hoofdinhoud
Nikon Coolpix 995 LCD Replacement
Wat je nodig hebt
  1. Nikon Coolpix 995 LCD Replacement, LCD: stap 1, afbeelding 1 van 2 Nikon Coolpix 995 LCD Replacement, LCD: stap 1, afbeelding 2 van 2
    • Turn the lens/flash assembly 90 degrees, until you see the two Phillips #00 screws,
    • Remove the two screws with a Phillips #00 screwdriver.
    • Flip the flash so that you can access the remaining two screws. Remove these screws following the same method as before.
    • Refer to the second image to locate the second set of screws. The relevant screws are highlighted in red.
  2. Nikon Coolpix 995 LCD Replacement: stap 2, afbeelding 1 van 1
    • Flip the camera up-side down.
    • Remove the two Phillips #00 screws located near the battery compartment.
  3. Nikon Coolpix 995 LCD Replacement: stap 3, afbeelding 1 van 1
    • Open the memory card compartment cover.
    • You can now see four screws under the cover. Remove all four screws.
    • Refer to the image to locate the four screws. Make sure that you remove only the four screws identified in the image.
  4. Nikon Coolpix 995 LCD Replacement: stap 4, afbeelding 1 van 2 Nikon Coolpix 995 LCD Replacement: stap 4, afbeelding 2 van 2
    • Use your thumb to carefully lift the bottom side of the casing near the battery.
    • Pay attention to a cable located at the top of the assembly, as it is prone to breakage. Refer to the second image to locate the cable.
  5. Nikon Coolpix 995 LCD Replacement: stap 5, afbeelding 1 van 1
    • Use a spudger to flip the tabs that hold the screen.
    • Refer to the image for more details. The tabs are circled in red.
  6. Nikon Coolpix 995 LCD Replacement: stap 6, afbeelding 1 van 1
    • Carefully lift the LCD from the bottom. It should come out fairly easily.
Conclusie
Cory Layman
89 Reputatie
3 handleidingen geschreven
UW Stout, Team 1-5, Zhou Fall 2011 Lid van UW Stout, Team 1-5, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G5
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 17
Altijd: 2,288
