Ga door naar hoofdinhoud
Nikon Coolpix 5400 Back Cover Replacement
Wat je nodig hebt
  1. Nikon Coolpix 5400 Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Remove one 3.0mm Phillips #0 screw from the top of the case.
  2. Nikon Coolpix 5400 Back Cover Replacement: stap 2, afbeelding 1 van 1
    • Remove two 3.0mm Phillips #0 screws from the card reader side of the case.
  3. Nikon Coolpix 5400 Back Cover Replacement: stap 3, afbeelding 1 van 1
    • Remove four 3.0mm Phillips #0 screws from the bottom of the camera.
  4. Nikon Coolpix 5400 Back Cover Replacement: stap 4, afbeelding 1 van 1
    • Remove one 3.0mm Phillips #0 screw from the side of the camera.
  5. Nikon Coolpix 5400 Back Cover Replacement: stap 5, afbeelding 1 van 1
    • Use a plastic opening tool to gently remove the back case from the rest of the camera.
  6. Nikon Coolpix 5400 Back Cover Replacement: stap 6, afbeelding 1 van 1
    • Pull the back of the camera cover apart.
    • Connecting wires that are still attached to the back cover are fragile.
  7. Nikon Coolpix 5400 Back Cover Replacement: stap 7, afbeelding 1 van 2 Nikon Coolpix 5400 Back Cover Replacement: stap 7, afbeelding 2 van 2
    • Remove the two 4.0mm Phillips #0 screws holding the circuit board to the back case.
  8. Nikon Coolpix 5400 Back Cover Replacement: stap 8, afbeelding 1 van 1
    • Pull the LCD screen cables in the direction that the wires are exiting the circuit board.
    • Pull the wire connector gently, the plastic is very fragile.
  9. Nikon Coolpix 5400 Back Cover Replacement: stap 9, afbeelding 1 van 2 Nikon Coolpix 5400 Back Cover Replacement: stap 9, afbeelding 2 van 2
    • Pull the toggle wheel wire connector up and away from the top of the camera.
    • Pull the button control panel wire connector up and away from the top of the camera.
    • Gently remove the wire connectors; the plastic is fragile.
  10. Nikon Coolpix 5400 Back Cover Replacement: stap 10, afbeelding 1 van 1
    • Remove the six 3.0mm Phillips #0 screws holding the button control panel.
    • Remove the back cover from the camera body.
Conclusie
Rhett Myers
231 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 419
