Ga door naar hoofdinhoud
Nikon Coolpix 4600 LCD screen Replacement
Wat je nodig hebt
  1. Nikon Coolpix 4600 LCD screen Replacement, Front and Rear Case: stap 1, afbeelding 1 van 2 Nikon Coolpix 4600 LCD screen Replacement, Front and Rear Case: stap 1, afbeelding 2 van 2
    • Locate the six screws on the outside of the camera (2 3.3 mm on the bottom, 2 5.25 mm on the left, and 2 5.25 mm on the right).
    • Using a Phillips 00 screwdriver, remove all of the six screws.
  2. Nikon Coolpix 4600 LCD screen Replacement: stap 2, afbeelding 1 van 2 Nikon Coolpix 4600 LCD screen Replacement: stap 2, afbeelding 2 van 2
    • Carefully pull the front and back case apart.
    • The front case is attached to internal components and cannot be removed independently.
  3. Nikon Coolpix 4600 LCD screen Replacement: stap 3, afbeelding 1 van 1
    • Look closely at the connection between the ribbon cable and the motherboard. Locate the two grey tabs on either side of the connecting bracket.
    • Slide the grey tabs toward the bottom of camera. Gently disconnect the ribbon cable from the motherboard.
    • After disconnecting the data ribbon, you can now separate the back case from the front case.
  4. Nikon Coolpix 4600 LCD screen Replacement, LCD screen: stap 4, afbeelding 1 van 1
    • With the lens facing down and the bottom of the camera facing away from you, lift up the right edge of the LCD screen (left side of the screen will be glued down).
    • Be careful not to push the front case too hard on the table when taking the LCD out or the lens will get stuck.
    • Insert plastic tool under the screen and gently pry up the left side of the screen until the glue seal is broken.
  5. Nikon Coolpix 4600 LCD screen Replacement: stap 5, afbeelding 1 van 1
    • Locate the orange ribbon cable and two wires (red and white) attached to the motherboard.
    • Lift up on the black clamp and pull out data cable.
    • Desolder the wires from motherboard. CAUTION: Improper desoldering can result in motherboard damage. Seek help if you do not have the necessary skills.
    • The screen should now be completely free from the camera.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Nathan Sperling
119 Reputatie
4 handleidingen geschreven
Cal Poly, Team 9-43, Regan Spring 2012 Lid van Cal Poly, Team 9-43, Regan Spring 2012
CPSU-REGAN-S12S9G43
5 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 11
Altijd: 1,240
