Ga door naar hoofdinhoud
Nikon Coolpix 3500 Front Cover Replacement.
Wat je nodig hebt
  1. Nikon Coolpix 3500 Front Cover Replacement., Battery: stap 1, afbeelding 1 van 1
    • Unlatch the battery cover and slide the cover out. Place cover to the side, it will not be needed for the next few steps.
    • Remove the battery.
    • Remove the battery cover without using excessive force. Keep in mind this cover is fragile.
  2. Nikon Coolpix 3500 Front Cover Replacement., Front Cover: stap 2, afbeelding 1 van 1
    • Remove the two 4.5 mm screws that sit next to the battery slot.
    • Remove the 3 mm screw that sits below the CF card slot.
    • Remove the 4.5 mm screw that sits above the digital I/O cover.
  3. Nikon Coolpix 3500 Front Cover Replacement.: stap 3, afbeelding 1 van 1
    • Remove the two 4.5 mm screws that sit inside the battery slot.
  4. Nikon Coolpix 3500 Front Cover Replacement.: stap 4, afbeelding 1 van 1
    • Remove the two 5 mm screws that sit near the camera strap eyelet.
    • Remove the camera strap eyelet.
  5. Nikon Coolpix 3500 Front Cover Replacement.: stap 5, afbeelding 1 van 1
    • Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
  6. Nikon Coolpix 3500 Front Cover Replacement.: stap 6, afbeelding 1 van 2 Nikon Coolpix 3500 Front Cover Replacement.: stap 6, afbeelding 2 van 2
    • Remove the five 3.5 mm screws that sit at the bottom of the camera.
    • Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
    • Do not apply too much force; two wires still connect the front cover to the motherboard.
  7. Nikon Coolpix 3500 Front Cover Replacement.: stap 7, afbeelding 1 van 2 Nikon Coolpix 3500 Front Cover Replacement.: stap 7, afbeelding 2 van 2
    • Using a spudger, detach the white-capped wire.
    • Using a spudger, detach the orange-capped wire and set the front cover aside.
Conclusie
richard guenther
183 Reputatie
6 handleidingen geschreven
Cal Poly, Team 30-38, Garner Spring 2010 Lid van Cal Poly, Team 30-38, Garner Spring 2010
CPSU-GARNER-S10S30G38
5 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,887
