Ga door naar hoofdinhoud
Nikon CoolPix S600 Lens Assembly Replacement
Wat je nodig hebt
  1. Nikon CoolPix S600 Lens Assembly Replacement, Front and Rear Casing: stap 1, afbeelding 1 van 1
    • With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
  2. Nikon CoolPix S600 Lens Assembly Replacement: stap 2, afbeelding 1 van 1
    • Remove the chrome side cover from the body of the camera.
  3. Nikon CoolPix S600 Lens Assembly Replacement: stap 3, afbeelding 1 van 1
    • Remove the four 3.2 mm screws on the bottom of the camera.
  4. Nikon CoolPix S600 Lens Assembly Replacement: stap 4, afbeelding 1 van 2 Nikon CoolPix S600 Lens Assembly Replacement: stap 4, afbeelding 2 van 2
    • Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
    • Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
  5. Nikon CoolPix S600 Lens Assembly Replacement: stap 5, afbeelding 1 van 2 Nikon CoolPix S600 Lens Assembly Replacement: stap 5, afbeelding 2 van 2
    • Gently separate the back cover from the body of the camera.
    • The back casing will still be connected to the circuit board by a ribbon
  6. Nikon CoolPix S600 Lens Assembly Replacement: stap 6, afbeelding 1 van 1
    • Use the tweezers to disconnect the ribbon from the circuit board.
  7. Nikon CoolPix S600 Lens Assembly Replacement: stap 7, afbeelding 1 van 1
    • Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
  8. Nikon CoolPix S600 Lens Assembly Replacement: stap 8, afbeelding 1 van 2 Nikon CoolPix S600 Lens Assembly Replacement: stap 8, afbeelding 2 van 2
    • Gently separate the front cover from the body of the camera.
    • The front casing will still be connected to the circuit board by a few wires
  9. Nikon CoolPix S600 Lens Assembly Replacement: stap 9, afbeelding 1 van 1
    • Remove the two 3.2 mm screws that hold the flash to the front cover.
  10. Nikon CoolPix S600 Lens Assembly Replacement: stap 10, afbeelding 1 van 3 Nikon CoolPix S600 Lens Assembly Replacement: stap 10, afbeelding 2 van 3 Nikon CoolPix S600 Lens Assembly Replacement: stap 10, afbeelding 3 van 3
    • Use the Spudger to remove the copper colored light bulb clip.
    • Remove the front cover entierly from the camera body.
  11. Nikon CoolPix S600 Lens Assembly Replacement, Lens Assembly: stap 11, afbeelding 1 van 2 Nikon CoolPix S600 Lens Assembly Replacement, Lens Assembly: stap 11, afbeelding 2 van 2
    • From the top view of the camera, remove the one 5.8 mm screw.
    • From the top view of the camera, remove the one 2.8 mm screw
  12. Nikon CoolPix S600 Lens Assembly Replacement: stap 12, afbeelding 1 van 1
    • Remove the three 3.4 mm screws from the back side of the camera.
  13. Nikon CoolPix S600 Lens Assembly Replacement: stap 13, afbeelding 1 van 1
    • Remove the two 3.4 mm screws from the side of the camera.
  14. Nikon CoolPix S600 Lens Assembly Replacement: stap 14, afbeelding 1 van 1
    • Separate the two metal body pieces from the rest of the camera.
  15. Nikon CoolPix S600 Lens Assembly Replacement: stap 15, afbeelding 1 van 2 Nikon CoolPix S600 Lens Assembly Replacement: stap 15, afbeelding 2 van 2
    • Gently remove the two ribbons connecting the lens to the mother board.
  16. Nikon CoolPix S600 Lens Assembly Replacement: stap 16, afbeelding 1 van 2 Nikon CoolPix S600 Lens Assembly Replacement: stap 16, afbeelding 2 van 2
    • Gently separate the camera lens from the mother board.
Conclusie
andreas anggasastra
116 Reputatie
5 handleidingen geschreven
Cuesta, Team 1-6, Zipperian Fall 2011 Lid van Cuesta, Team 1-6, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G6
2 Leden
6 handleidingen geschreven
Één opmerking
Any place where I could buy a new lens for the camera nowadays?
thesilver - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 14
Altijd: 3,245
