Ga door naar hoofdinhoud
Nikon CoolPix S5 Wrist Strap Holder Replacement
Wat je nodig hebt
  1. Nikon CoolPix S5 Wrist Strap Holder Replacement, Wrist Strap Holder: stap 1, afbeelding 1 van 1
    • Remove the wrist strap from the wrist strap holder by untying the string at the end of the wrist strap.
    • This will allow for the wrist strap to be pulled through the wrist strap holder.
  2. Nikon CoolPix S5 Wrist Strap Holder Replacement: stap 2, afbeelding 1 van 1
    • Using the thumb, firmly push the Battery/SD cover in the middle and in the direction of the arrow on the Battery/SD cover.
    • This will cause the Battery/SD cover to pop open.
  3. Nikon CoolPix S5 Wrist Strap Holder Replacement: stap 3, afbeelding 1 van 1
    • Use the Phillips screwdriver to remove the four screws on the bottom of the camera.
  4. Nikon CoolPix S5 Wrist Strap Holder Replacement: stap 4, afbeelding 1 van 1
    • Using fingers, pull the silver side panels from each side.
  5. Nikon CoolPix S5 Wrist Strap Holder Replacement: stap 5, afbeelding 1 van 1
    • On the right hand side of the camera, remove the two screws from the wrist strap handle by using the Phillips screwdriver.
Conclusie
Patty Richeson
99 Reputatie
4 handleidingen geschreven
Clemson, Team 12-5, Benson Spring 2013 Lid van Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 8
Altijd: 548
