Ga door naar hoofdinhoud
Fix Your Stuff
Right to Repair
Parts & Tools
Inleiding
This guide is to be used to install the plastic LCD screen cover in the case that it becomes damaged or no longer functions properly due to overuse. A Phillips screwdriver will be needed to complete this installation.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove wrist strap by unknotting the strap.
    • Remove wrist strap by unknotting the strap.
  2. Open SD/Battery cover.
    • Open SD/Battery cover.
  3. Remove the four screws on the bottom of the camera using the Phillips-Head screwdriver. Remove the four screws on the bottom of the camera using the Phillips-Head screwdriver.
    • Remove the four screws on the bottom of the camera using the Phillips-Head screwdriver.
  4. Pull the silver side panels on each side. Pull the silver side panels on each side.
    • Pull the silver side panels on each side.
  5. On the right side of the camera (that contains the wrist strap loop), use the  screwdriver to remove the two screws holding the backplate in place. Repeat this step for the left side.
    • On the right side of the camera (that contains the wrist strap loop), use the screwdriver to remove the two screws holding the backplate in place.
    • Repeat this step for the left side.
  6. Pull the back silver faceplate to separate it from the rest of the camera. Pull the back silver faceplate to separate it from the rest of the camera.
    • Pull the back silver faceplate to separate it from the rest of the camera.
  7. Press lightly on the outer surface of the plastic LCD screen cover in each corner. The plastic LCD screen cover should pop out of the back plate.
    • Press lightly on the outer surface of the plastic LCD screen cover in each corner.
    • The plastic LCD screen cover should pop out of the back plate.
Conclusie
Josh Miller
84 Reputatie
3 handleidingen geschreven
Clemson, Team 12-5, Benson Spring 2013 Lid van Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
4 Leden
7 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 272
