Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide is to be used to install buttons in the case that the buttons are damage or are no longer functioning properly due to overuse. A Phillips screwdriver will be needed to complete this installation.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove wrist strap by unknotting the strap.
    • Remove wrist strap by unknotting the strap.
  2. Open SD/Battery cover.
    • Open SD/Battery cover.
  3. Remove the four screws on the bottom of the camera using the Phillips-Head screwdriver. Remove the four screws on the bottom of the camera using the Phillips-Head screwdriver.
    • Remove the four screws on the bottom of the camera using the Phillips-Head screwdriver.
  4. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  5. Pull the silver side panels on each side. Pull the silver side panels on each side.
    • Pull the silver side panels on each side.
  6. On the right side of the camera (that contains the wrist strap loop), use the  screwdriver to remove the two screws holding the backplate in place. Repeat this step for the left side.
    • On the right side of the camera (that contains the wrist strap loop), use the screwdriver to remove the two screws holding the backplate in place.
    • Repeat this step for the left side.
  7. Pull the back silver faceplate to separate it from the rest of the camera. Pull the back silver faceplate to separate it from the rest of the camera.
    • Pull the back silver faceplate to separate it from the rest of the camera.
  8. Using fingers, lift up button plate on the side closest to the LCD screen.
    • Using fingers, lift up button plate on the side closest to the LCD screen.
  9. Pull on ribbon cables to disconnect ribbon cables.
    • Pull on ribbon cables to disconnect ribbon cables.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Patty Richeson
75 Reputatie
4 handleidingen geschreven
Clemson, Team 12-5, Benson Spring 2013 Lid van Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
4 Leden
14 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 308
